Tire Pressure
Tire Pressure
Postby Mtflyr » Thu May 18, 2017 5:17 am
Just checking what tire pressure do you guys typically run? I have Kumo 165/80/15 front and 195/80/15 rear and usually go with 20-22 front and 24 rear.
Re: Tire Pressure
Postby danstern » Thu May 18, 2017 5:54 am
Spot on.
21F, 24R here.
Re: Tire Pressure
Postby Mtflyr » Thu May 18, 2017 6:04 am
Thanks Dan. Hope some other chime in here.
Re: Tire Pressure
Postby RVosari » Thu May 18, 2017 12:36 pm
Peter…that depends on your driving style…these cars oversteer…so if you go into a curving 30 mph type highway off-ramp at 45 mph and lift your foot from the gas pedal, the car will “tuck”…(turn-in perhaps 20 degrees)…if it turns- in 40+ degrees you have too much understeer and need to adjust tire pressures.
For most people… the ideal… is going into that turn with the throttle neutral…(constant) and having the car neither understeer nor oversteer.
If you don’t drive fast…use the lowest tire pressure you can… to take harshness out of the suspension [8D]
Re: Tire Pressure
Postby Mtflyr » Thu May 18, 2017 2:57 pm
Thank ReV
It's Pete. :D I agree with what you've written just trying to see what pressures others typically are running for std road use.
Re: Tire Pressure
Postby Larry Jowdy » Thu May 18, 2017 3:47 pm
In the area of under and over steer, here's a great chart
http://www.morpca.org/drivers-education ... oversteer/
Re: Tire Pressure
Postby beck688 » Sun May 21, 2017 6:24 am
Understeer -> the front hits the wall
Oversteer -> the rear hits the wall
Horsepower -> how hard you hit the wall
Torque -> how far the wall moves
Re: Tire Pressure
Postby RVosari » Sun May 21, 2017 6:51 am
Don't forget...neutral steer and the passenger side hits the wall {left hand turns}...gives you a chance to hop out and check out the result :)
Re: Tire Pressure
Postby beck688 » Sun May 21, 2017 12:12 pm
That is just a graze a mere fleshwound
Re: Tire Pressure
Postby gixxerblade » Mon May 22, 2017 11:13 am
19F
20.5R
gixxerblade
Senior Member
Senior Member
Re: Tire Pressure
Postby RicardoSwe » Sat Jun 03, 2017 8:58 am
Must commit to memory & recall as I steer into the turns...
beck688 wrote:Understeer -> the front hits the wall
Love it!
After experimenting w oversteer/understeer, I arrived at:
Tire pressure 22 Front , 24Rear
Richard --
RicardoSwe
Re: Tire Pressure
Postby Mtflyr » Sat Jun 03, 2017 8:05 pm
Thanks Richard.
Re: Tire Pressure
Postby DannyP » Wed Jun 28, 2017 5:09 pm
I typically run 22F 25R
Users browsing this forum: No registered users and 10 guests
