Headlight assembly
Re: Headlight assembly
Postby Kris Courtney » Fri Nov 10, 2017 3:19 pm
Changed my pivot points .Drilled new ones .Got rid of the old pivot points and the top adjuster .No more side to side but can go up and down .Retaned the bottom adjustment for that.Got the lights where I wanted.test them tonight.
Kris Courtney
Postby Kris Courtney » Fri Nov 10, 2017 10:23 pm
Yes worked great ,Nice to see the ground underneath you . I have only H-4 s haven't stepped up to LED s yet . which LED s did you buy . Bought the yellow German lens's every marker on the road lights up with those .Dont know if there legal here.but thats the theme barely legal.
Kris Courtney
Postby Mtflyr » Sat Nov 11, 2017 6:48 pm
Hey Carlos,
Sorry took so long to respond. Just returned from a trip to Cali.
Do a search on this site for LED lights. Myself and others posted. I love the Vintagecarleds they are simple plug and play. i posted pic's too.
Postby EEricson » Sun Nov 12, 2017 5:52 am
Great job, Kris. I, for one, would love to know the details of your mods.
Postby beck688 » Sun Nov 12, 2017 10:17 am
Kris Courtney wrote:Yes worked great ,Nice to see the ground underneath you . I have only H-4 s haven't stepped up to LED s yet . which LED s did you buy . Bought the yellow German lens's every marker on the road lights up with those .Dont know if there legal here.but thats the theme barely legal.
You can also use Stained glass paint on the inside of the lens - decide you don't like it a little lacquer thinner will remove it.
Postby Kris Courtney » Sun Nov 12, 2017 12:20 pm
First make bucket even with headlight using the old pivot points and adjusters. about 3/8 s all around.
Than get a flexible measuring tape.Start center of the running light at the bottom and wrap all the way around on top of headlight should end up with 12 3/8 s
.Mark 6 1/8 and 18 1/4
3/8 down these are the pivot points.
Put locking nut and bolt in holes.
Pull out old pivot points
Put fake screw/ bolt in top adjustment
The bottom one I put the top spring and the bottom spring together wound them inside each other. Made the adjustment feel more solid.
Did do the garage test and the lights are still centered
Easy job
Kris Courtney
Postby EEricson » Sun Nov 12, 2017 6:01 pm
Thanks!
Users browsing this forum: Google [Bot] and 14 guests
