Access to the Rear Brake Light Bulb
Postby Armodilo » Wed Jan 10, 2018 2:01 pm
Hey,
Does anyone know how to remove the rear brake light so I can change the bulb? There's no access from the inside, just a small hole for the wiring to get into the fender and no visible screws or access point on the outside of the lights.
I can turn the chrome bezel and light if I use both hands but it doesn't appear to do anything but turn.
Any ideas?
Cheers,
Beck Spyder #171 (2276cc)
1963 Porsche 356B T6 S90
2018 Porsche 911 GTS
Armodilo
Re: Access to the Rear Brake Light Bulb
Postby Mtflyr » Wed Jan 10, 2018 7:42 pm
You may be able to pull it out from the inside of the clam-shell. The bulb on mine is attached to it's wired plug which is a sort of press fit into the lens assembly.
You pull it out from the wired plug end change the bulb and press it back into the lens rear hole.
Pete
Mtflyr
Postby Armodilo » Thu Jan 11, 2018 3:29 am
Thanks Pete,
There's absolutely no access from the inside of the clamshell, that area is completely sealed off, just the little hole to allow the cable to run into that area. I'd have to cut an access hole on both sides to be able to get my hand in far enough to work on anything in there -- strange setup.
Cheers,
Armodilo
Postby albaran » Thu Jan 11, 2018 7:56 am
Some lenses are held on by the rubber base and others are a twist in type such as this:
http://www.sierramadrecollection.com/55 ... 26861.html
Postby Larry Jowdy » Thu Jan 11, 2018 10:50 am
Depending on the fixture, the lens is held on by silicone sealant. Twist the glass to break the bond then reseal the lens when you've replaced the bulb
Postby Armodilo » Thu Jan 11, 2018 10:56 am
Thanks. So hold the chrome bezel and try to turn the light to break the seal... should be fun :)
Armodilo
Postby DannyP » Tue Jan 16, 2018 8:53 am
The old lenses were glued in place. The new ones from Beck or Vintage should come off easier. The new ones have three nubs that protrude slightly on the base. There are three cutouts on the bezel of the lens. You have to trurn the lens and it will pop off with a little persuasion.
Postby Armodilo » Tue Jan 16, 2018 2:27 pm
They're old ones - 1992 or so, so I'm sure they're glued in. I've tried turning them to find a way to get them to loosen with no luck. I'm really scared to break them -- thinking I might add an access hole on the inside of the wheel arch to avoid destroying them by trying to get them off, who knows what they're glued together with.
Armodilo
Postby SpyderMike » Wed Jan 17, 2018 10:05 pm
When I built my car back in 1989 I did as you suggested and drilled hole sin my inner wheel well to gain access.
l my b
SpyderMike
Old Timer
Old Timer
Postby Armodilo » Thu Jan 18, 2018 5:45 am
Thanks, how large an opening did you add, do you happen to have a pick where you put them?
Cheers,
Armodilo
Postby EEricson » Thu Jan 18, 2018 3:03 pm
The big hole is about 5 inches. Image
Postby Armodilo » Fri Jan 19, 2018 3:35 pm
Awesome, thank you.
Armodilo
Postby SpyderMike » Sun Jan 21, 2018 7:36 pm
sorry for the late reply, but it was the smallest hole big enough to get my hand through.
l my b
SpyderMike
Old Timer
Old Timer
Postby Armodilo » Tue Jan 23, 2018 3:47 am
Thanks Mike, going to drills a couple of holes this weekend :)
Armodilo
Users browsing this forum: EricTheRed and 7 guests
