Heim Joint Linkage...how to build drawings & details
Re: Heim Joint Linkage...how to build drawings & details
Postby TomD » Wed Feb 14, 2018 10:25 am
On a tangent – is anyone using the Gene Berg fan housing mounted linkage? I realize that if you are not running a doghouse then this might not be an option. Once installed and adjusted both throttle bodies open and close smoothly with minimal load on the throttle shafts. It does have a few advantages over the hex shaft setup IMO.
TomD
Postby RBP » Thu Feb 15, 2018 2:26 pm
There is this to think about as well. Looks much easier to sync at high RPM, trying to tighten the jamb nuts without changing the sync is a real PITA.
http://www.tangerineracing.com/throttlelinkage.htm
Postby egrant5329 » Thu Feb 15, 2018 4:43 pm
Sync Link had a lot of hubbub a while back and then kind of quietened down, probably due to price. It's a very nice system and I think Raby uses it a lot.
https://www.limebug.com/product/view/21 ... f-delortto
Users browsing this forum: EricTheRed and 3 guests
