Original VIN Plate Info
Postby Anta » Sun May 06, 2018 9:04 am
Hi All, I have a blank copy VIN plate for my Spyder which is a Martin & Walker based on a 55. I am not sure of the correct info to stamp into it....I have some details from searching, just wondered if anyone knew or had a photo of an original? Am annoyed as my pal was standing next to one in Silverstone this week! Thanks.
Info required for VIN plate is.....
Typ (Type) - 550 or RS550? What did they put here?
zul Gesamtgewicht (Perm Total weight) - 900kg?
zul Achslast Vorn kg (perm. axle load front kg) - 450kg?
zul Achslast hinten kg (perm. axle load rear kg) - 450kg?
Fahrgestell-nr (Chassis Nr) - Will put my cars real one here
Baujahr (Construction Year) - 1955
Martin & Walker 550 Spyder
Anta
Re: Original VIN Plate Info
Postby Larry Jowdy » Sun May 06, 2018 1:30 pm
Postby Anta » Sun May 06, 2018 1:41 pm
Thanks Larry. I saw those, on the first one it was the missing left hand side I was after, the model type for a Spyder etc. Make sense?
Cheers
Ant
Anta
Postby Larry Jowdy » Sun May 06, 2018 2:01 pm
If you aren't able to find a photo of a V.I.N. plate, use your Private Message service on this site and send Andrew a PM his user name is gotowo He probably has a photo of a vin plate. His web site is http://www.type550.com
Postby Anta » Thu May 10, 2018 2:10 pm
Thanks Larry, appreciate the steer. ant
Anta
Users browsing this forum: No registered users and 12 guests
