4 Post Lift
Re: 4 Post Lift
Postby RBP » Mon Aug 20, 2018 9:29 am
If you have 12' of height the doors don't matter. Modify the track so it goes as high as you can and use a side mounted direct coupled door actuator. I have 12' height as well and thats how mine is set up. I can even work on my car with the lift at full height and have the door open.
Re: 4 Post Lift
Postby sjgharib » Tue Aug 21, 2018 8:50 am
cool - what brand are those side mounted actuators?
Re: 4 Post Lift
Postby RBP » Tue Aug 21, 2018 10:05 am
Re: 4 Post Lift
Postby EEricson » Tue Aug 21, 2018 5:14 pm
Now THAT"S A SHOP!
Re: 4 Post Lift
Postby albaran » Wed Aug 22, 2018 7:37 am
If you go the garage forum you will see that the Liftmaster 8500 is the motor of choice for people installing lifts. I have had mine for over 4 years and it has operated flawlessly.
Re: 4 Post Lift
Postby sjgharib » Thu Aug 23, 2018 8:39 am
Excellent info. I have some work to do, as currently I have extension springs on my door too. So I need to convert to torsion springs at the same time I do the high lift track... that'll set me up for the liftmaster, although i'm thinking I can live with a manual door initially (especially over the winter), since I won't be opening that door much!
The "to do" list just keeps getting longer!
Simon
Users browsing this forum: No registered users and 8 guests
