\"Pushrod Spyder Engine\"
Postby Kuzu356 » Sat Jan 24, 2004 5:41 pm
I have been working on this project on and off since 3 years
I am almost nearing to have a running prototype engine ready ....And also building
a website for this project named ..\"pushrodspyderengine.com\"...will include many details and pictures for your enjoyment.I hope with this very special concept
I have added a great touch to our beloved 356 push rod engine by Installing the Original 4 Cam Shroud and twin Fans with the original Generator stand .My background
being a Tool&Die maker really helped me to manage this very challenging project.
I hope you Enjoy the pictures ..
http://images.andale.com/f2/114/114/127 ... 010645.JPG
http://images.andale.com/f2/114/114/127 ... 010644.JPG
http://images.andale.com/f2/114/114/127 ... 010646.JPG
Regards,
Ibrahim Kuzu
51 coupe
52 coupe
2- 53 coupes
55 S/R coupe under restoration
Very interested in owning a Vintage 550 spyder.
Kuzu356
Postby tmpusfugit » Sat Jan 24, 2004 7:20 pm
Nice work! Makes for a far better look for the 356 engine....but where does one find the original shroud and generator parts these days?
Jim DuBois
tmpusfugit
Postby Ricardo » Sun Jan 25, 2004 6:04 am
Keep us posted with your engine progress and web site.
Ricardo
Postby Kuzu356 » Sun Jan 25, 2004 3:24 pm
Jim,Orig Carrera Generator stand made to fit on pushrod case will be done
in a month( machining,......Casting is allready done)
Ventury ring on the Fan Shroud also very soon will be finished.
Orig Carrera Fan shroud made to fit on the pushrod engine is in the works
All the other parts prototypes are all build ready for testing.......
I will not put anything in market unless all the parts are fully tasted in normal
driving condition,Hot /cold wheather.....
Thank you
Ibrahim
Kuzu356
Kuzu356
Postby Jake Raby » Sun Jan 25, 2004 3:47 pm
I have a testing platform and outline that will prove if it works, and plenty of cooling system test experience!
Jake Raby
Raby Engine Development
http://www.rabyenginedevelopment.com
Vintage VW, Porsche and Subaru Engine Development
Jake Raby
Contributing Vendor
Contributing Vendor
Postby tmpusfugit » Sun Jan 25, 2004 5:34 pm
thanks Kuzu356 for the response. WOuld certainly like to see more of your product when finished.
Jim DuBois
tmpusfugit
Postby Kuzu356 » Sun Jan 25, 2004 8:38 pm
Jake,I will visit your testing graund with my complete running Engine
I have little more to go ...I am looking forwart to test this
pushrod spyder engine with these \"work of Art Engineering of Original 4 cam generator stand,Fan shroud,Twin blade Fan etc.I will be very pleased
to have your experience touch this( never been done with the full 4 cam
original cooling parts ) pushrod Engine project.
Thank you
kuzu356
Kuzu356
Postby Steve Courtney » Wed Jan 28, 2004 3:54 am
=D>
Kuzu
I am running a 356/912 engine in my spyder and have a spare on the stand. I would be very interested in purchasing a set up when they are available.
contact me @
scourtney@crucibleservice(dot)com
Thanks
Steve Courtney
The \"Kuzu\" fan project
Postby Jeff S » Thu Feb 03, 2005 11:42 pm
Did anything definative ever come from this project ? [?]
Jeff S
Jeff S
Postby Kuzu356 » Fri Mar 04, 2005 9:13 pm
Jeff,
You can read more info on the Pushrod Carrera engine at the
Tech Engines/Mechanical section under:
Any News on the 4 Cam Fan Shroud???
[ Goto page: 1, 2 ]
Ibrahim Kuzu
Kuzu356
Push rod Spyder engine
Postby Heiko » Fri Apr 04, 2008 7:55 pm
What ever happened with this project? Just curious.
Heiko
Heiko
Postby Kuzu356 » Mon Apr 21, 2008 4:11 pm
Heiko,
Sorry,for the late respond.So busy with building Carrera fan shrouds
have nine orders and each order is taking 3~4 weeks part time work.
Please visit :356registry.org
Porsche 356 club,where we are more active when you get a chance or
can email us at :
kuzu356@aol.com
for more detail info.So far we delivered seven Carrera 4 cam cooling system and soon you will hear from them with their cars in some shows.
Best Regards,
Ibrahim Kuzu
Kuzu356
Postby Larry Jowdy » Mon Apr 21, 2008 5:31 pm
Did you ever run a heat test? If so what were the results?
Postby prototype4 » Tue Apr 22, 2008 1:01 pm
It is so good to hear from you KUZU....... and to find out you have gone into short run production. Did you like my Typ 547 engine contribution? ;)
Ohhhhhh........I'm a lumberjack and I'm OKAY,
prototype4
Postby yorkemike » Tue Apr 22, 2008 2:20 pm
How much are you charging for your units?
Mike
200? Vintage
\"For every complex problem, there is a
solution that is simple, neat, and wrong.\"
H.L. Mencken
yorkemike
Return to 356 talk
