How to clean your idle jets on Weber Carb's
Postby Larry Jowdy » Mon Oct 12, 2015 2:58 pm
Go here for a view of your carburetors. viewtopic.php?f=19&t=8411 Remove the screws, make sure you don't lose the green "O" rings. Remove the idle jets from the holder, take a twist tie and strip off the paper. Run the twist tie into the tiny hole and then blow through the tiny hole to remove any crap.
