Weber 44IDF exploded view CLEANING IDLE JETS
Postby Larry Jowdy » Wed Jul 19, 2006 3:36 pm
Click on the image below, you'll see a box that contains a photo. Double click on the photo and it will expand.
If your engine is backfiring, you probably have an exhaust leak, an intake leak or, dirty idle jets
Using a flat blade screwdriver, remove the idle jet screw (don't lose the small green "O" ring). Carefully pull the jet from the brass holder and then take a twist tie, remove the paper and insert the steel wire into the idle jet from the small end. Clean out any crud and then replace the idle jet back into the holder and insert the holder into the carb body and tighten (not too much, just enough to hold it in place)
Also make sure the rubber \"O\" ring is in place on the jet holder
44IDF71.pdf
DOWNLOAD THIS AND PRINT
(262.3 KiB) Downloaded 4102 times
