latches again
latches again
Postby wacopsc » Tue Sep 08, 2015 11:28 am
Hi, new owner here with a low time Beck original 550. Driving and getting to learn the car ect. but the latches have given me occasional problems. I read ALL the posts ect but have come up with a simple solution that works for me and is reverse-able and causes no damage ect.
I cut two pieces of 8mm threaded rod and finished the ends nicely on a lathe. Each piece 2 3/4"
long
replaced the plunger with the rod, locked it in place with a nut and put the spring and moulded plastic washer back on with another nut with some tension on it.
Closed the clam and installed a washer and nut on the end of the rod on the other side of the latching mechanism and snugged it down thru the carb doors .
Its worth it for me to have to take a few minutes to open the clam this way instead of the noisy pop open and the attendant engine noise. Now just peaceful driving.........regards Paul
wacopsc
Re: latches again
Postby egrant5329 » Wed Sep 09, 2015 11:53 am
Just get the reworked latches. It's an easy 10-15 minute fix, its done and no more problems. I don't know if everyone is selling them now, but I purchased mine from Greg at Vintage. After I did I wished I had done it sooner.
Re: latches again
Postby danstern » Wed Sep 09, 2015 7:09 pm
+1 on Greg's latches. Vintage has a simple solution.
Re: latches again
Postby Harry » Mon Dec 28, 2015 7:29 pm
Thanks guys! Is Greg on the forum?
Harry
latches again
Postby egrant5329 » Tue Dec 29, 2015 4:30 am
His website is http://vintagespyders.com .
