Special Edition Chamonix/Beck/
Postby Larry Jowdy » Tue Jan 06, 2009 5:48 am
This Registry will assist those looking for other owners and will also provide their general geographical location
Add to this forum if you own a car assembled by the Special Edition crew or if you own a Special Edition home built vehicle You can also add any modifications, improvements etc.
Remember, to add your name, city, state, (country), modifications etc
Feel free to add photo's of your vehicle
Postby drdriddle » Wed Jan 07, 2009 8:33 am
Dustin Riddle
HArtford, WI USA
Standard Equipment
1. 2.0 liter inline 4 cylinder Audi/VW group engine with 125 hp and 5 speed transmission
2. VDO Gauges
3. Leather interior
4. Disc brakes all around
5. Alloy wheels
Items ordered with car:
1. Cable Shifter
2. MPH conversion
3. Bonnet straps
4. Banjo steering wheel
5. Racing mirror
Items completed/*designed by owner
1. Oil Cooler grill frame with modified fiberglass grill cover*
2. Original style front and rear turn signals
3. Aluminum master cylinder kit for hydro clutch and brakes
4. Partial aluminum interior (floorboards only at this time)*
5. Five point racing seatbelt. Drivers side only
6. Push Button Starter
7. Modified exhaust with 10 inch glass pack and single outlet*
8. Modified cold air intake*
9. Quick release steering hub
10. Donnington wheel with Horn button modified to accept Porsche emblem overlay
11. Racing Helmet Fairing
12. Aluminum Hard Tonneau Cover *
13. Wendler Badges
14. Nurburgring Badge
15. Porsche Emblems
16. S/S fuel lines
17. Modified Pedal cluster changed to include hydraulic clutch line
18. Original style Emergency brake
drdriddle
Chamonix 550s
Postby fasternu » Sun Jul 12, 2009 10:57 am
Purchased from D&M motorsports in January 2009.
The serial number is 55000942
Silver Blue with Red interior
2.0 Audi/VW inline 4 watercool
Radiator in front - does not seem light at high speeds
MSO states year of mfg is 2005
4x100 hubs, disk brakes front and rear with proportioning valve
185/65 15 inch 7 inch rims all four corners
DeDion Rear suspension with Coil overs
Roll Hoops
fasternu
Re: Special Edition Chamonix/Beck/
Postby dlearl476 » Sat Apr 22, 2017 1:27 pm
:D I guess this is as good as anyplace to say hello. Hello
As we all know, Chuck learned to keep records from the Italians, so details are sketchy on my car. As per my Avatar, it's #201 and I believe it was assembled at the factory in California, as that's where all the paperwork originated. But, as its spent the last little while with Carey in Indiana, I'm going to call it a Chamonix!
Carey just replaced the sketchy Jamar shifter with a cable set up and the Home Depot hardware clutch with a hydraulic unit, and replaced the straight pipe with a CB Performance/Flowmaster exhaust.
AFAIK, (info from the PO) it's got a 2.0L CB Performance engine and Freeway Flyer trans, when I bought it, after sitting for a number of years, it had just had a re-spray in Silver and the interior redone in Red Leather. I bought it about 40 miles from Bremen, so first stop was Special Editions and they mounted the glass windscreen and made me a tonneau for it, and gave it the once over so I could drive it back to NYC, where I was living at the time.
The odo reads 46,000. I have no idea if it's accurate. Might be one of the highest mileage Spyders around if so. I bought it in 2012 and every time I tried to work on it I threw out my back, so it pretty much languished under its cover until last year, when I dropped it off in Indiana on my way home to Utah.
It should be a dependable cruiser now, and I fully intend to put it in daily rotation with my Smart and my Porsche 968 while the weather is nice. Hopefully I can do the little bits to get it up to 100% without too much trauma. :D
Postby SpyderMike » Sat Apr 22, 2017 6:33 pm
Welcome. I have #191 and I bought it directly from Beck in Upland, CA near where I lived at the time in late 1980s.
Postby dlearl476 » Sun Apr 23, 2017 3:22 pm
:wave
Was your car a kit or a turn-key? Do you know when it was built? My car originally had a 1996 Title. Thankfully Utah allowed me to register it as a 1955 Beck Special Interest Vehicle so I can use a 1955 Plate on it. (It's one of my OCD fetishes, having period plates on my cars.)
Postby Larry Jowdy » Mon Apr 24, 2017 4:13 am
Not Sure where the state of "HATU" is located LOL
Postby SpyderMike » Mon Apr 24, 2017 3:47 pm
dlearl476 wrote:Was your car a kit or a turn-key? Do you know when it was built?
Mine was a kit and I bought it from Chuck in late 1989 or may be even early 1990.
Postby Armodilo » Sun Aug 27, 2017 3:46 pm
Hi all,
I recently acquired Beck #171, (CA Kit build) that has been in British Columbia Canada for the past 25 years (1992 title), now we have it Ontario Canada. We had to jump through a lot of hoops to get it on the road here but it's finally plated and I had it out and about this weekend -- what a riot!
- CB Performance 2276 with Dual Weber 44 IDFs.
- Ranchero Type 1 Trans
- Lots of other unknowns, will find out as I go.
Beck Spyder #171 (2276cc)
1963 Porsche 356B T6 S90
2018 Porsche 911 GTS
Armodilo
