550 Spyder Sander 550
Postby sander 550 » Fri Jan 20, 2012 6:53 am
Dear All,
First I like to introduce.
My name is Sander and come from the Netherlands
I'm building a 550 spyder based on a beetle frame from "69
I started this project as a dream from me and my father, our hobby was to see the 1000 miglia in Italy we went every year
Than we start to produce a Miglia Porsche, only he get an exident and past away from us....
I'll finish his dream.....
I hope, couse this takes emotions.....and.....
I'll stop my posting on this f.. forum, as you already delete my post it has no sence for me to inform you all with my project.... as my emotions are not interested
sander 550
Re: 550 Spyder Sander 550
Postby sander 550 » Fri Jan 20, 2012 7:04 am
sander 550
Postby sander 550 » Fri Jan 20, 2012 7:09 am
Dear All.
on this moment my project is stopped I have to wait for delivery of parts from vintagespyders (Greg)
I orderd this last June only still nothing at my address, as I see on this forum I'm not the only one who have this problem!
Can anyone help me????
I orderd:
1 x 550-9 the engine grill (pair)
1 x 550-51 Rear bonnet release
1 x 550-02 Gold "plated" Spyder logo
1 x 550- 33 drum covers set of four, will fit over stock vw 5x205mm bolt patern drums
1 x 550-40 dash handle
1 x 550-39 leather bonnet straps tan
1 x 550-03 fender mirror hardware and mounting template
1 x 550-10 headrest with tan leather pad removable with mounting stud
1 x 550-25 gauge package uses vw speedo cable
3 x 550-31 tail and turn light kit
1x 550-20 leather seat package (Tan) with mounting rails two seats
2 x 550-00 wendler badges pair
1 x 550-22 silver 3" lap only belt pair
1 x spyder starter button
1 x inside rear view mirror
3 x lower trim
1 x 550-32.2 ignition switch
sander 550
Postby NL Spyder » Fri Jan 20, 2012 11:26 am
Nice car , i swear i saw it before somewhere, somehow ;)
NL Spyder
Postby SpyderMike » Fri Jan 20, 2012 11:38 pm
Nice project Sander! Where in NL are you? I lived in Amstelveen for a couple of years working for Philips on a KLM project. My wife and I were married in the castle Kasteel de Haar near Utrecht. What a nice country you live in!
Postby sander 550 » Sun Jan 22, 2012 1:25 am
I hope parts are sent right now by Greg, I'm looking for those airhoops on the back hood... :D
does any have a good idea where to order!!!
:D
sander 550
Postby Ralf » Sun Jan 22, 2012 5:26 am
It´s a sweet detail, but be aware that sooner or later, they will cause small cracks in the fiberglas.
"Fibersteel" is developing a kind of "aluminium-cap" to be fixed with rivets on top of the body and a gasket in between.
Maybe you should give this a try.
Ralf
Postby duck944t » Tue Jan 24, 2012 1:28 pm
Mine have been in since the car was built in 1991 and have created no crack problems. The one problem that you might have to be aware of is that they will limit the height of your intakes/carbs/filters. So depending on what combination you are running, they may not work. I use short intakes (also run phenolic spacers between heads / intakes / carbs to aid in cooling from short intakes) with 48IDFs and 2.5" velocity stacks. IDAs will be a problem if you want to use any filters.
duck944t
Postby sander 550 » Thu Jan 26, 2012 12:07 am
duck944t wrote:Mine have been in since the car was built in 1991 and have created no crack problems. The one problem that you might have to be aware of is that they will limit the height of your intakes/carbs/filters. So depending on what combination you are running, they may not work. I use short intakes (also run phenolic spacers between heads / intakes / carbs to aid in cooling from short intakes) with 48IDFs and 2.5" velocity stacks. IDAs will be a problem if you want to use any filters.
Do you have any idea where to order those?? and who deliver theme also :)
Fibersteel dosn't have theme anymore [:(!]
sander 550
Postby duck944t » Thu Jan 26, 2012 8:24 am
Ooops, I wasn't thinking about your car having the engine in the rear, so my above comments don't apply. #-o
duck944t
