Porsche 547 Fan shroud
Postby Bic » Mon Jan 21, 2013 1:27 pm
HI Everyone,
After searching everywhere I have decided to build a very close 547 Fan Shroud replica for the Porsche 550 Kit.
I am still tweaking the Shroud and i am making the bucks for all the Aluminum pieces needed for the real look.
I have attached a photo of the first mach up of the Shroud and the first attempt at spinning the velocity cover for the fan ( i have not cut out the opening yet).
I am working on the cone piece to cover the fan nut. I will have it soon.
I will be taking orders soon.
Comments welcome
Bic
Bic
Re: Porsche 547 Fan shroud
Postby RS-60 mark » Mon Jan 21, 2013 2:08 pm
Where's the photo?
Postby Bic » Mon Jan 21, 2013 3:46 pm
Sorry it got deleted.
Thanks for pointing that out.
Bic
Bic
Postby Bic » Thu Jan 24, 2013 1:45 pm
Side view of Shroud
Bic
Postby Devin » Fri Jan 25, 2013 7:19 am
how much?
Devin
Postby Bic » Fri Jan 25, 2013 10:48 am
Hi Devin,
Im not sure yet,
There will be the fans shroud, rear velocity ring, center nut cone. and ring similar to back but with supports for the generator. Kinda like the 911 style. I will be woking on that next. Probably around $1500.00 for all the pieces.
I will be dyno tested for cooling before release.
Here is todays progress. I will probably do a limited run.
Bic
Postby daVinci 550 » Sat Jan 26, 2013 5:54 pm
Looks good Bic. Can't wait to see the finished product. [8D]
Is this for the Type I or Type IV, or both engines?
Matthew Gardiner
Vintage Spyder #412
Digital Media & Graphic Design
daVinci 550
Postby Bic » Sun Jan 27, 2013 5:02 am
I have it on a Type one
I m. Not sure if will fit but when I finish the plug and so to production I can find out if it will work.
I don't have a type 4 to try
Bic
Bic
Postby daVinci 550 » Sun Jan 27, 2013 8:33 am
Thanks. Just curious. Can't wait to see the finished product, anyway.
Matthew Gardiner
Vintage Spyder #412
daVinci 550
Postby cam550 » Sun Jan 27, 2013 9:52 am
Looks real good. At that price and if it fits and is tested on a Type IV I will sign up for one.
Cam
cam550
Postby Bic » Sun Mar 03, 2013 10:31 am
I am starting to work on the Generator bracket for the Shroud.
I have not spun the inner liner for the generator but I am finalizing the outer ring and supports.
There will be an inner ring, that the generator will side into and the shaft ad 2 mounting bolts will pass through the back and attache like on the old backing plate.
Here is the update.
Bic
Bic
Postby Bic » Sat Mar 09, 2013 11:20 am
A little closer.
I have moved up in thickness on the Aluminum from .040 now to .090"
This makes a nicer feel and is much more solid.
Next step is to Tig all the pieces.
Bic
Postby fificox » Wed Apr 03, 2013 12:48 pm
+1..
i have lot's of interests in that CARRERA fan..
keep me posted once available
philippe
fificox
Postby Bic » Mon May 06, 2013 1:01 pm
Here are some new photos of the final Plug ready for the Mold and the New generator mount.
Bic
Will probably have a sample at Kit Car Carlisle.PA
before liner and first fin. 3 fins will support the generator and the support strap will be hidden.
Bic
Postby wong-yoo » Mon May 06, 2013 2:15 pm
Stunning... That is looking vey impressive.
When do you think you will be ready to sell them?
wong-yoo
