550 Spyder gas tank w/fuel sender, gas cap, fittings, NEW
Postby SeductionMotorsports » Wed Nov 09, 2016 8:24 pm
I have a brand new modified 550 Spyder fuel tank that will fit into any Seduction Motorsports 550 Spyder, Vintage Spyder 550, Beck 550 Spyder, Thunder Ranch 550 Spyder and most others. This was made for a customer, they upgraded to our aluminum fuel cell instead, brand new and ready to be installed.
What you get:
-Brand new steel gas tank (10 gal) with TIG welded and shaved original filler side neck, flush mount vented gas cap has been installed. Fuel sending unit mount ring has been welded on.
-Brand new modified fuel sending unit (float arm has been flipped to work on 550 Spyders).
-Rear mount breather vent for fuel injected breather vent, -8AN roll-over fitting, comes with cap plug for those running aircooled engines, breather vent for those running fuel injected engines, and also you can run a 90-degree fitting there and run a hose out the bottom or to an evamp canister if needed.
-(2) welded on -6AN ports on the bottom, one for fuel feed line and one for fuel return line. If running an aircooled engine, use the provided -6AN cap and cap off the return port. If running fuel injected engine, use the second port as your fuel return line.
-90-degree -6AN to push-lock fuel hose fitting for feed line.
-Kevlar, gloss black, tank coating on exterior top.
-Flat black on bottom of tank.
-Inside comes coated with gas tank sealer.
-Pressure tested.
Price: $399 USD + $45 USD shipping within the USA. We have only one in stock since this was a special order. Please send payment here: www.paypal.me/SeductionMotorsports/444
If you are international and need a shipping quote or have any questions, please email me: daniel@seductionmotorsports.com or call the shop during business hours: 480-404-1117
Thank you,
-Daniel
www.SeductionMotorsports.com
Instagram: seduction_ms
Moderator
Moderator
