Spyder Parking Brake Levers - Seduction Motorsports
"Builder of turn-key Vintage 550 Spyders, SM550 Spyder Outlaws, & 356 Coupes"
Moderators: Larry Jowdy, SeductionMotorsports
Postby SeductionMotorsports » Fri Sep 12, 2014 8:24 am
We are currently finishing up our Spyder parking brake levers. They will not be an exact copy of the original parking brake, why? Because the original design was junk. Springs failed, pieces were to flimsy, the flow and operation was engineering of the 1950s... case and point, our Spyder handbrake will be more superior to any on the market.
Designed in CAD and Solidworks, strength tested, rigidity test, and flow tested for moving parts. We will include a mounting base option that makes these universal, you can even mount one up in a 356 Speedster. Constructed of stainless steel, waterjetted and CNC cut for precision edges. TIG welded for strength and aesthetics. All mounting hardware will be stainless 10.9 grade metric button heads. We will include mounting instructions and all handbrakes will be pre-assembled and ready to mount.
Here are some teaser pictures... more pictures to come. Still working on final build cost before we release a sale price.
For those who are interested in getting on the pre-order list, send me an email at: daniel@seductionmotorsports.com
Thank you.
-Daniel
www.SeductionMotorsports.com
Instagram: seduction_ms
Moderator
Moderator
Re: Spyder Parking Brake Levers - Seduction Motorsports
Postby SeductionMotorsports » Tue Dec 02, 2014 8:33 pm
We can ship them with the base welded together or with the base and bar not affixed. Everything is stainless 304, TIG welded with stainless 318 hardware and mounting hardware. These are extremely easy to install and upgrade your old VW style parking brake. These are spring loaded so the teeth will not bind up and break off. These teeth are also stainless 304... no heat treatment needed since you cannot heat treat stainless. These are handsdown the BEST restomod parking brake for your Spyders on the market.
If you are interested, we will have them up on our updated website here shortly. Until then you can email sales@seductionmotorsports.com for all inquires.
Moderator
Moderator
Return to Seduction Motorsports
