Subaru Engine Conversion Aluminum ECU Bracket & Case
"Builder of turn-key Vintage 550 Spyders, SM550 Spyder Outlaws, & 356 Coupes"
Moderators: Larry Jowdy, SeductionMotorsports
Postby SeductionMotorsports » Thu Dec 18, 2014 8:46 pm
Our new ECU protective case mount for Subaru engine conversions into Spyder/Speedsters. Constructed from US grade T-6061 aluminum. We media blast the outside then brush it to give it the satin brushed aluminum finish. Neoprene spacer washers are used to mount to between the firewall and aluminum mount so there is no vibration. We TIG weld the edges. Stainless button head screws are used for mounting. Just another detail that comes standard on our Seduction Motorsports built 550 Spyders and 356 Coupes.
With this case you can mount your Subaru EJ engine conversion ECU to the backside of your Spyder or Speedsters firewall (or anywhere in the vehicle depending on how long your wire harness is... we can also build you a high end Mil-spec wire harness with weather-packed connectorsc) , yet still protecting it using our Weather-packed plug-n-play wire harness. These will be available for purchase January, 2015. Email: sales@seductionmotorsports.com
The last picture is it installed behind the driver's seat on the backside of the firewall in a 550 Spyder.
Thank you,
-Daniel
www.SeductionMotorsports.com
www.Facebook.com/SeductionMotorsports
Instagram: seduction_ms
Inquiries: daniel@seductionmotorsports.com
Builder of 550 Spyders, SM550 Spyder Outlaws & 356 Coupes
Moderator
Moderator
Return to Seduction Motorsports
Users browsing this forum: No registered users and 2 guests
