martin & walker Information
Vendor Advisories, Kudos, recommendations, etc.
Postby NelsonM » Thu Nov 21, 2013 8:49 am
I'm looking for information on the M&W kits. I apologize in advance, I am sure this has been discussed many times, but I can't locate any prior posts.
I am looking for specific knowledge on overall quality of the base kit (frame & body). If we move forward it will probably be built with performance in mind, so want to make sure we are starting with a solid foundation.
Again, any comments or direction to prior posts would be appreciated.
NelsonM
Re: martin & walker Information
Postby SeductionMotorsports » Thu Nov 21, 2013 6:11 pm
Never heard of them.... you looking for a turnkey or do-it-yourself kit?
www.SeductionMotorsports.com
Instagram: seduction_ms
Moderator
Moderator
Postby SpyderMike » Thu Nov 21, 2013 9:47 pm
Try a search on "walker" or "martin" it pulls up over 200 posts...
Postby NelsonM » Fri Nov 22, 2013 6:37 am
sofresh: Not turn key, prefer basic roller.
NelsonM
Postby bathspyder » Fri Nov 22, 2013 11:40 am
I drove an M&W Spyder for about 7 years.
I believe that the chassis and bodies are good.
The current cars have wishbone front suspension with rack and pinion steering. At the back there is DeDion suspension with radius rods and a Panhard rod.
All in all a very good basis for a performance car that will stick to the road.
As standard they accept type 1, type 4, and Alpha Romeo flat 4. Versions with Porsche flat 6 and Suby power have been built.
Search on the site for Mighty Spyder to see an alloy bodied M&W with a very special Jake Raby engine.
The M&W website is 904gts.com
Ron
bathspyder
Postby NelsonM » Tue Nov 26, 2013 3:36 pm
Ron: Thank you, that is exactly what I was looking for. Nelson
NelsonM
Return to Vendor Discussions
Users browsing this forum: Majestic-12 [Bot] and 2 guests
