Headrest pad question.....removal?
Postby RandyM » Sat Sep 02, 2017 7:46 am
Hey guys,
I searched the board but didn't see anything regarding this. I have found several 550's that have the headrest pad on the car. I like them and can see how they would be useful on a long drive but can they be removed?
If they are removed does it leave a few mounting holes that stand out? Me personaly I like the clean look of no pad, but if I bought a car with it already installed didn't know whats involved to remove it and how bad the holes stick out.
Hope this question makes sense.
Randy
Randy
RandyM
Re: Headrest pad question.....removal?
Postby Mtflyr » Sat Sep 02, 2017 10:07 am
Hey Randy,
I agree on the helmet faring, I didn't really want one but my SE/Beck had one when I bought it. Standard, it attaches with one wing nut in the middle inside the clam-shell (CS) see it in the first picture top left. I have clear plastic over the CS shaped a little wider along the edges of the fairing and clear Velcro at the end to help keep it from moving. There are two small holes in the CS.
Postby Mtflyr » Sat Sep 02, 2017 10:08 am
A few more pic's:
Postby RandyM » Sat Sep 02, 2017 10:31 am
Pete,
Thanks so much for the pictures, that really helps visualize it. Do you leave yours on all the time or run it both ways. I assume once off it's not too unsightly, just the two small holes.
Randy
Randy
RandyM
Postby Mtflyr » Sat Sep 02, 2017 12:23 pm
Randy,
I just leave it on, but it is easy to remove. There's only one hole. The fairing has a plate inside going to each edge with the threaded screw in the center which goes through the clam-shell. The wing nut with washer is used to tighten it down. It's why I have the Velcro in the back to keep it from moving side to side.
Postby danstern » Sat Sep 02, 2017 7:56 pm
My Vintage is the same. One hole with a bolt and wing nut. It can rotate so I clear vinyl'ed the clam and clear tape towards the rear to prevent rotation. Run it all the time, but one hole would be there if removed.
Postby egrant5329 » Sun Sep 10, 2017 4:48 pm
People often glass in a second bolt to the helmet fairing to keep it from moving. I think the fairing will probably rub the paint no matter what you do given enough time.
Postby danstern » Sun Sep 10, 2017 6:47 pm
I put a paint protection film on the rear clam under the headrest to prevent rubbing the paint. Seems to work fine.
Postby DannyP » Wed Sep 13, 2017 3:18 pm
I have a Vintage new shape headrest with one bolt. It doesn't move. It did wear the paint a little on the old car, but I only have about 700 miles on the new one.
I drilled the hole a bit bigger than 1/4", and installed a 1/4-20 rivnut in the clamshell. Then I drilled out the threads. Gives a nice finished look if I ever remove it.
Postby danstern » Thu Sep 14, 2017 6:14 am
On the old rear clam I had added a 1/16" rod near the rear and drilled a small hole in the clam to stop rotation. Still got rubbing. The new calm just has the one bolt, but will rotate so I use clear tape to prevent rotation and the paint film to stop rubbing.
Users browsing this forum: Google [Bot] and 5 guests
