Engine Rebuild Timelapse
Postby BB73 » Thu Nov 30, 2017 2:54 pm
https://youtu.be/S3cMPJjuj2w
Good to see my insurance dollars at work for entertainment
BB73
Re: Engine Rebuild Timelapse
Postby Larry Jowdy » Fri Dec 01, 2017 4:49 am
Kind of reminds me of "me" back in the 70's. I had a part time business rebuilding VW engines. Back then, I'd remove 3 engines on Saturday/Sunday then take them apart, Monday afternoon I'd send the cases out for machine work, get them back on Wednesday and Thurs and Friday evenings I would rebuild all three then on Saturday and Sunday I'd install those engines, remove 3 more and start over.
Postby mason » Thu Dec 07, 2017 8:53 pm
Looks like fun. If I knew I could have done it in 6 minutes, I would have built my own. :)
mason
Postby egrant5329 » Sat Dec 09, 2017 6:47 am
I have thought about trying it, but engine kits like CBPerfs are in the $4k-$5.5K range. That is a fair amount of money to experiment with. Maybe when mine needs rebuilt I might give it a try.
Postby RVosari » Sat Dec 09, 2017 10:25 am
Well…unless you have a rod through the case…a simple measure and re-build consisting of:
Sleeving the lifter bores / consider new lifters
Check/reconditioning the rod bushings
Align honing the case
Polishing the crank and changing all bearings
Reconditioning the cylinder heads
New Cylinders and pistons
Cam Drive/distributor gear replacement
Degreeing Cam…replace if out-of-spec
Out-of-pocket should be less than $ 1000, not including your labor :)
