It's in!
It's in!
Postby darisb » Sun Sep 04, 2016 4:08 pm
My wife and I got the long block into my Spyder today, in spite of my broken wrist. I bought a one ton hoist at Harbor Freight, and rigged it up to our tractor. I used three straps and some metal bracket to suspend my motor. It worked out well.
I ended up having to unbolt the transmission and lift it up a couple inches in order to get the front pulley past the torsion bar tube.
After we had it in, I started fitting some of the sheet metal.
Not easy with my right wrist in a cast, plus it was really hot.
darisb
Re: It's in!
Postby gixxerblade » Mon Sep 05, 2016 10:24 am
I'm sure it'll work great Daris. I don't know if it's just my computer but I can't see the pics.
gixxerblade
Senior Member
Senior Member
Re: It's in!
Postby RS-60 mark » Mon Sep 05, 2016 7:45 pm
I can't see the pictures either. But I'm sure Harbor Freight has something to use for that too!
It's in!
Postby egrant5329 » Tue Sep 06, 2016 2:46 am
When I installed mine I removed the pulley and it was still a tight fit.
Re: It's in!
Postby darisb » Wed Sep 07, 2016 5:41 am
Can you see the pics now?
darisb
