Steering Box
Steering Box
Postby Drummerskey » Sat Sep 17, 2016 11:35 am
What is the best way to take out the steering box?
Hard, easy?
Drummerskey
Re: Steering Box
Postby Drummerskey » Tue Sep 20, 2016 8:24 am
Maybe I should clarify since I haven't got a response. My mechanic was looking at the steering box and it is leaking a little. In order to pull it, he was asking what the best way was since the set up in the Spyder is different than a VW. He wasn't sure if there was enough clearance around the axle to pull it out and was looking for experienced input
Drummerskey
Re: Steering Box
Postby Larry Jowdy » Tue Sep 20, 2016 8:47 am
Some will come out with no problem. Others not so much. If it won't come out from the bottom, cut the fiberglass and create a hole then get some sheet metal from Home Depot and make a cover. Serves 2 purposes, one, it will allow the steering box to be removed easily and the other is it allows access to the steering box adjustment screw if your steering gets sloppy.
Re: Steering Box
Postby Drummerskey » Tue Sep 20, 2016 2:25 pm
Thanks
Drummerskey
