Clutch cable
Clutch cable
Postby SpeedwaySpyder » Thu Nov 24, 2016 7:20 am
I have a Beck 550 and will be replacing the clutch cable. What cable is being used? Length? etc.?
SpeedwaySpyder
Re: Clutch cable
Postby thundercow » Fri Nov 25, 2016 10:34 pm
Please post pictures of the cable at the foot pedal and where it meets the carbs.
I just replaced mine, it took like 10 minutes. the trick is to figure out what you have.
thundercow
Re: Clutch cable
Postby Larry Jowdy » Sat Nov 26, 2016 5:26 am
Speedway, Your best bet is to call Kevin or Carey Hines at Special Edition. They have cables in stock and will ship one to you.
Re: Clutch cable
Postby RVosari » Sat Nov 26, 2016 5:38 am
How did you work the cable to the rear...is it just a simple push-through or did you have some sort of chase ?
Re: Clutch cable
Postby SpeedwaySpyder » Sat Nov 26, 2016 9:07 am
I'll call them and have them send me one.
SpeedwaySpyder
Re: Clutch cable
Postby thundercow » Sat Nov 26, 2016 4:49 pm
I tried to PM you, it didn't go through. All these cars are different, but this can't be that hard. Carey Hines will know, if your car is a Beck.
thundercow
Re: Clutch cable
Postby GoldBarBill » Wed Sep 13, 2017 1:06 pm
How do you access the clutch pedal to replace the cable? From under the car or from inside the cockpit?
Goldbarbill
GoldBarBill
Users browsing this forum: No registered users and 8 guests
