Popping exhaust
Popping exhaust
Postby sjgharib » Tue May 16, 2017 10:51 am
What makes my exhaust pop on throttle lift off while still in gear?
I have a 2.5L Subaru with fuel injection. Exhaust is custom 4-2-1 with basically glass pack mufflers (it's loud!).
I know some boy-racers like the noise, but should it be a concern? I basically sound like an F1 car under braking.
Thanks!
Simon
Re: Popping exhaust
Postby Larry Jowdy » Tue May 16, 2017 12:09 pm
I could be an exhaust leak. They're prone to leaking at the manifold. Usually easy to tell as there will be carbon deposits on the cylinder head. If the exhaust system is sectioned together and clamped, look for traces of carbon on the inner pipe. Another condition is you're going extremely lean when you lift your foot off the gas pedal.
Re: Popping exhaust
Postby EEricson » Wed May 17, 2017 6:32 pm
My Subie burbles just a little but I put it down to the short pipes. I like Larry's diagnosis; unless you're running Webers or something there's not much on a Suby that can go wrong and give you this symptom.
Re: Popping exhaust
Postby sjgharib » Mon Sep 11, 2017 12:33 pm
Very lean? Interesting to understand that phenomenon. I've done some more research and that sounds like where to start.
I'm running a megasquirt ECU, and I know I've got it cutting the fuel on over-run... I'll try turning that off and see what happens. I'm also betting my fuel map is too low at low vacuum, which apparently (according to the megasquirt community) is a common thing to get when you let the computer tune itself...
It's a one piece welded exhaust, no visible leaks (at least that I can see)...
Simon
Re: Popping exhaust
Postby Larry Jowdy » Tue Sep 12, 2017 7:46 am
If the exhaust is truly a one piece then check your exhaust manifold gaskets. They're notorious for leaking with aftermarket exhaust systems.
Re: Popping exhaust
Postby sjgharib » Fri Sep 29, 2017 5:45 am
I'm going to replace the whole thing with a new stainless one this winter, so I'll check the gaskets... I actually built the entire exhaust myself from mandrel bends and muffler components (http://coneeng.com). I was poor at the time (spent all my $$ on other parts) and thus I went with mild steel tube instead of stainless. I don't like the rusty look, so exhaust 2.0 (100% stainless) will be a project in the coming weeks!
Has anyone had any experience with the "auger" style muffler inserts? I was going to try them instead of perforated tubes and steel wool.
