Front wheels outside fenders. What's the fix?
Re: Front wheels outside fenders. What's the fix?
Postby RBP » Tue Jun 27, 2017 1:00 pm
I have a Vintage and run 16" aluminum alloy wheels with 4.5" BS. The rears are 6" with 205/55/16 and the fronts are 5" with 175/55/16. Fit is perfect, no rubbing or contact of any sort.
Postby DannyP » Wed Jun 28, 2017 2:25 pm
On my old car, CSP brakes fit fine with the 4.5" rims that Greg sent with it. The centers were moved a little from whatever stock backspace was.
When I changed to the Airkewld 4 piston brakes, this brought them out further. I was able to get another 3/8" backspacing by moving the centers myself. It was a real pain in the ass. Line it up, 4 tack welds, install on balance machine and check runout. Grind tacks, move, measure, try again. I did it, but what a pain.
FYI, I have over 40,000 HARD miles, lots of autocross and DE time on 4.5" wheels with 185/65 tires. They ain't coming off, trust me. And yes, I understand a minimum 5.0" is recommended.
New car has same Airkewld brakes all around(with single piston e-brake rear caliper) but the 2" narrowed beam makes a perfect fit with the Vintage 190 aluminum wheels. Thanks Greg!
I am very happy with the performance of these brakes. I can't seem to induce fade, which is a VERY good thing!
I am sure that Greg will put a narrowed beam in a new car, but it would be pretty tough to do in an existing car.
Postby DannyP » Wed Jun 28, 2017 2:26 pm
Rudy, that sounds like a sweet setup.
Postby RVosari » Wed Jun 28, 2017 4:40 pm
Aaaah... but they don’t have to “come-off”…they simply roll on the rim and negatively affect your turn-in…and transitions… particularly in tight turns…this is simply fact…not opinion !
Go check what Carroll Smith says !
Postby DannyP » Wed Jun 28, 2017 5:11 pm
It's OK, I like it when it negatively affects my turn-in. Alternative facts!
Postby RBP » Thu Jun 29, 2017 4:15 am
Danny, did you get a new car /550? You refer to the old car and new car. Did you sell the white one and build a new one? I only remember the white one (painted a few years ago) with the 2165 engine. Hope your seeing decent weather there. I've never seen a summer like this. Rains almost everyday and still cold. Had a fire last night to warm up the house! Crazy, normally its so hot and humid that you can't sit outside.
Postby egrant5329 » Thu Jun 29, 2017 7:18 am
RBP wrote:I have a Vintage and run 16" aluminum alloy wheels with 4.5" BS. The rears are 6" with 205/55/16 and the fronts are 5" with 175/55/16. Fit is perfect, no rubbing or contact of any sort.
Rudy your 175/55/16 will be nearly an inch shorter (22.6mm) and an 10mm skinnier than the 185/65/15 tires, which would probably be enough so mine wouldn't rub. The builders may have fixed the issue on newer versions too. https://www.tacomaworld.com/tirecalc?ti ... -175-55r16
What wheels are you running?
Postby RBP » Thu Jun 29, 2017 7:56 am
Hi Ed, I ordered 5" wide for the front and 6" wide for the back, both 16" and have a 4.5" BS. They are from here http://www.alloyreplicas.com/model-a/ nice and light too.
I think you have a Beck if I remember right. Just wondering if the inner well clearances are the same as with a Vintage.
Postby egrant5329 » Thu Jun 29, 2017 8:23 am
Rudy nice wheels! I'd like those in full silver. I don't know the answer to the clearance question.
Postby RBP » Thu Jun 29, 2017 8:40 am
The pic is fresh cut aluminum. As per the original wheels on a 550 they will fade as they oxidize and look and be authentic.
Postby egrant5329 » Fri Jul 21, 2017 10:30 am
RBP wrote:The pic is fresh cut aluminum. As per the original wheels on a 550 they will fade as they oxidize and look and be authentic.
I wonder if most people buy the polished aluminum wheel instead of the silver powder coated aluminum wheel that Greg at VS sells. I like all 3 looks Polished, powder coated and the authentic looking oxidized look.
Postby RVosari » Sat Jul 22, 2017 11:12 pm
Going back to the front end width...Mr. Camper and his road racing (SCCA) Karmann Ghia (at over 2000 lbs) successfully used the standard KG front disc brake set-up...which is quite a bit narrower than the much heavier Wilwood set-up [8D]
Postby DannyP » Mon Jul 31, 2017 11:20 am
I think Greg sells mostly powdercoat. That is what Lenny and I bought. I like all three as well. I wouldn't want to keep the polished ones shiny though. Powdercoat washes up easily.
