PBS Shifter Installation
Postby Tony46 » Thu Sep 07, 2017 2:02 pm
Can anyone help with explaining how the shift rails work on a Type 1 transmission, and advise which rail is which.
I am guessing from the PBS instructions that the bottom rail would be reverse? I am hoping that a good explanation on how the rails shift (direction) and what gear it affects, would assist in the installation of this shifter.
ImageInstructions by Tony Donofrio, on Flickr
Image20170905_114853 by Tony Donofrio, on Flickr
Tony46
Re: PBS Shifter Installation
Postby DannyP » Wed Sep 13, 2017 2:45 pm
Tony, follow the instructions. You only trim the bottom fork which is reverse. Lay a straightedge from the edge of the 3-4 fork to the bolt like it says. Scribe a line. It doesn't take much. If you take too much off, you won't be able get into reverse.
Top fork is 3-4
Middle is 1-2
Bottom reverse.
Pull for R-2-4, push for 1-3.
The reverse lockout spring is very strong
Postby Tony46 » Thu Sep 14, 2017 3:39 pm
Thanks Danny
I completed the install on Sunday. I tend to overthink things fearing that I will mess it up. The grind went fine, but I managed to mess up an eye when a metal particle bypassed my safety goggles. Dr says I'll be fine in 5 days...I'm just glad I didn't mess up the shift forks. [-X
Tony46
Users browsing this forum: No registered users and 8 guests
