Remote Oil Filter / Heat
Postby Armodilo » Sun Apr 22, 2018 3:11 pm
Hi guys,
Stupid question: I installed a remote oil filter on my new 2276 engine and the filter heats up to the point that it's pretty much untouchable after about 10 - 15 minutes of the car running. The temp gauge barely moves and the remote oil cooler / fan aren't starting up, so I assume this is normal but wanted to double check. How hot should a remote filter get while operating?
Beck Spyder #171 (2276cc)
1963 Porsche 356B T6 S90
2018 Porsche 911 GTS
Armodilo
Re: Remote Oil Filter / Heat
Postby EEricson » Sun Apr 22, 2018 4:58 pm
Should run at about your oil temp, which should be somewhere between 180 and 220F. So, I guess, compare it to filling a beer can with boiling water and then wanting to pick it up bare-handed.
Postby Armodilo » Sun Apr 22, 2018 5:00 pm
Makes sense, just making sure.
Armodilo
Postby RS-60 mark » Mon Apr 23, 2018 12:34 pm
What might NOT make sense is your oil temp gauge "barely" moving.
Get yourself one of these: https://www.amazon.com/dp/B07BN84K23/re ... rd_w=t2pUO
Stick it in the dipstick hole to measure oil temp and look at the dashboard gauge. Then you will know how to relate the position of the gauge needle and actual temperature. Also, if the actual oil temp is over 180 you should feel the hose going to the remote cooler. It should be hot. If oil coming out of the remote cooler is still over 180, the remote cooler fan should be running.
Postby Armodilo » Tue Apr 24, 2018 11:35 am
Thanks, I will get one to double check!
Armodilo
Postby albaran » Wed Apr 25, 2018 8:21 am
You could also put a gauge in line with the oil line to check the actual temperature.
Users browsing this forum: No registered users and 13 guests
