Beck Trans Leak
Beck Trans Leak
Postby StanB » Sat May 12, 2018 1:30 pm
Any ideas on simple way to keep trans oil off exhaust pipes?? Thanks
StanB
Re: Beck Trans Leak
Postby DannyP » Sat May 12, 2018 2:24 pm
Replace the swingaxle boots?
Re: Beck Trans Leak
Postby StanB » Sat May 12, 2018 4:26 pm
Thanks but it's the seal in the trans. Mechanic says don't rebuild but make shield to divert oil away from pipes. Thought maybe someone had used something called 'Blue Devil' before.
StanB
