Rear brake system on early Beck Spyder
Postby TuxedoSam » Fri Aug 24, 2018 4:20 pm
My spyder is a early year build from Beck with rear disc brake equipped. Does anyone know which brake rotor and pads used on the rear? Somehow one of the brake pads was gone and damaged the rotor. The current Beck Co. has no clue.
TuxedoSam
Re: Rear brake system on early Beck Spyder
Postby DannyP » Sat Aug 25, 2018 3:50 am
4 lug or wide5? gotta start there. Pictures help as well.
Beck build, homebuilt?
Postby TuxedoSam » Sat Aug 25, 2018 10:47 am
4 lug Beck build. I don't have any picture since the car is in the repair shop now and they don't know what's on it.
TuxedoSam
Postby DannyP » Sat Aug 25, 2018 6:51 pm
The only thing I know is that Beck's use 1968 long swing axles. Without pictures to see what you have, I don't think anyone could possibly help you.
Postby TuxedoSam » Thu Aug 30, 2018 1:35 pm
Thank you, Danny! I ended up order a kit from CB performance. The caliper was frozen which caused the issue.
TuxedoSam
