static cling vinyl stickers: interest check!
Don your flame-proof suit and come on in! IF YOU CAN'T STAND THE HEAT THEN GET OUT!!!!
Post anything you wish within reason that is \"off-topic\" from a Spyder.
Postby &1 » Wed Sep 05, 2012 4:04 am
There are lots of race-related stickers/decals in the world, but most of them have a back with glue to make them stick on the car. Putting those stickers on a car is pretty permanent and removing them usualy destroys the sticker and may cause damage to the car...
I found a company that can make these stickers on heavy duty static cling vinyl (no glue, easy removable and re-usable) in high quality (far better than most 'stickers' that are sold on for example ebay).
A lot of Spyders -also on this forum- are 'clean' and have no racing stickers on them. I can imagine that you would like it when you could give your car a (non permanent) racy look every now and then and/or for 'special occasions': just put a couple of these static cling stickers on your car and you have the 'race look', just remove them afterwards and re-use them whenever you want...
Am I correct? Would there be any interest in these static cling 'stickers'?
I was thinking about the following stickers:
- Mobiloil Pegasus
- Castrol oil
- Bosch spark plugs
- Heuer
- Mille Miglia
- Koni
- Telefunken (the square version)
Any others?
&1
Re: static cling vinyl stickers: interest check!
Postby arajani » Mon Sep 10, 2012 11:22 am
&1:
This sounds great -- I would be interested in the Mobil pegasus, Heuer and Mille Miglia for sure.
Your car looks amazing. What a masterpiece! I am excited for you!
Anand
arajani
Return to Off Topic (formerly Flamers)
