Heim Joint Carb Linkage...how to build drawings
A forum where you can load photo's of your car, work in progress, completed projects and just about anything else that you'd like to "show off"
Postby JRGilbert » Mon Mar 19, 2018 5:25 am
Feel free to contact me if additional information is needed.
This is how I did it.
You're welcome to the information.
You do it your way...
JRGilbert
Re: Heim Joint Carb Linkage...how to build drawings
Postby DannyP » Wed Mar 21, 2018 9:53 am
The only thing I'll add is for CB linkage it will be a little cheaper. No need for aluminum plate, you can just cut the ears off the existing carb bases. File, grind, sand flush and flat.
The hexbar has a 8mm or 5/16" hole in the end. So instead of 6mm heims, I bought 5/16" female heims.
I drilled the bar deeper and threaded for 5/16"-18, then loctited in a 3" long bolt, then cut the head off.
Easy peasy, and about 20-25 bucks.
Ended up like this:
https://www.speedsterowners.com/fileSen ... 404046.jpg
Return to Show off Photo Gallery
Users browsing this forum: No registered users and 0 guests
