Postby albaran » Tue Oct 09, 2018 7:58 am
I swapped out the banjo wheel (which I still have) to a smaller wood wheel like a lot of people do. I'm not as svelte as I once was. The larger wheel also caused some throttle control issues. I gained some more clearance by mounting he seats directly to the floor. You appear to have some cross members running under the seats. is that raising your seats up?
Postby EEricson » Tue Oct 09, 2018 5:53 pm
Yep. I wanted mine on steel with nothing protruding through the floor and so here we are. The good news is you can always just cut them out if need be, or eliminate the slider in favor of a couple 3/16 bits of flat stock, which would gain about 3/4 or an inch.
As is, I fit OK; still had a notch of adjustment to move back when I left it last night. Tonight I adjusted the pedals back today and drilled my steel frame bits to move the seat about 1/2 inch to the right (it was just barely rubbing the frame tube after the reupholstery job).
I'll test fit again before final assembly but for now I think it's gonna be alright.
Postby EEricson » Sun Oct 14, 2018 5:46 pm
Postby EEricson » Sat Oct 27, 2018 5:53 am
Making this rather larger cable shifter box fit in the Spyder and look sort of like it's supposed to = many hours.
https://alongcameaspyder.wordpress.com/2018/10/27/shifter-e-brake-fabrication-seats-and-compromises/
Postby EEricson » Mon Dec 24, 2018 10:24 am
Update on my build. Not much going on but I'm still progressing.
https://alongcameaspyder.wordpress.com/2018/12/24/continued-slow-going/
Postby EEricson » Sun Feb 10, 2019 4:51 pm
Postby Ralphc » Fri Feb 15, 2019 1:33 pm
Saw your earlier post regarding sway bar. Here's a link to an in-the-beam source https://www.apexspeed.com/forums/showth ... T-Sway-Bar
I used one. Since it leaves you with only one pack of torsion leaves, I replaced a couple of stock leaves with Sway Away heavy duty leaves to restore front spring capacity.
For everyone's info Formula FST racers are formula Vee but allow the ball joint front end. Info for those interested in Zero roll rear suspension & etc.
Postby EEricson » Sun Mar 03, 2019 3:45 pm
Thanks, Ralph. I'm going to do something with a separate bar. Not sure just how yet.
Meanwhile, I took a break from blocking the car out this weekend to make some 550-style clam latches.
Postby DannyP » Tue Mar 05, 2019 4:53 pm
Nice work Ed, I like the latches.
Postby EEricson » Wed Mar 13, 2019 2:39 pm
Latches are done. https://alongcameaspyder.wordpress.com/2019/03/11/original-style-clam-latches-done/
That was fun.
Now to get this dang thing painted!
Postby EEricson » Sun Mar 17, 2019 4:32 pm
Still working on getting a painter. One guy looked at it and was encouraging and then flaked off. I talked to another guy yesterday.
While waiting for those guys I decided to make a Spyderesque cover for the gas tank. It's coming along rather well.
I blogged yesterday: https://alongcameaspyder.wordpress.com/2019/03/16/fuel-tank-cover/
By the end of today we had
Postby EEricson » Tue Mar 26, 2019 2:36 pm
The car is now with the painter. He says 2-3 weeks. Fingers crossed.
Postby EEricson » Tue Apr 02, 2019 4:02 pm
Paint is going on the car.
It's happening, men. This is not a drill.
Postby egrant5329 » Wed Apr 03, 2019 6:32 am
Looks nice! I like the color. I have always liked Seinfeld's spyder and almost went that direction on mine. I stayed with white and regret it a little. What interior color are you doing?
Postby EEricson » Wed Apr 03, 2019 3:33 pm
It's the sand/tan and red barberpole vinyl.
Here's a blog post re the paint: https://alongcameaspyder.wordpress.com/2019/04/03/paint-is-happening/
Here's a shot of the seats.
I have enough material to do the interior properly as original, and will see to that as soon as the engine is in and the switches and levers are all sorted.
